01-16-2022 03:37 PM - last edited on 01-16-2022 03:41 PM by CS_Agent
Hello,
A friend tried to change my phone number for me and its not working can I have it just switched back to the original please?
The number that was tried: xxxxx
Original Number: xxxxxxxxxx
J h
xxxxxx
DOB:xxxxxxx
01-16-2022 03:40 PM
@hlaj Please use the downward arrow on the top right of your post and immediately delete your name/number and all other personal details from your post as you're posting on a public forum.
You will not able to get back your number if you changed numbers unless it was originally issued by PM/Koodo/Telus.
You can send a message to customer support either via the chatbot bottom right for assistance or send a private message to CS_Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
01-16-2022 03:40 PM - edited 01-16-2022 03:45 PM
Where did the 226 number come from? Was it new here or did you bring it from another provider?
Edit: whoa a CSA monitoring things
01-16-2022 03:40 PM
01-16-2022 03:42 PM
Hey so sadly to say i dont think its possible to get your old phone number back. You could get a similar one but not the same one. ALSO PLEASE REMOVE PERSONAL INFORMATION FROM THE SITE.
01-16-2022 03:46 PM
@z10user4 Yes, that was a fast edit from CSA...perhaps they're monitoring the forums more than usual?
01-16-2022 03:48 PM
Changing Your Number up to 4 times every 30 days after you’ve activated.
To change, go to your Self Serve Account here and:
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent,
Good Luck....
01-16-2022 03:49 PM
@dabr : I sure wish they cared more about the quality and usefulness and relevance of posts that we see all too frequently.
01-16-2022 05:00 PM
You mean they should delete post above?
01-16-2022 05:03 PM
@hlaj wrote:Hello,
So what happened when your friend tried to change your number? Did you get new one or you have No number now?
Once number is changed it cannot be switched back as it goes into pool of unassigned numbers. If you have time you can daily scroll through available numbers and if extremely lucky you will see it again (which I doubt).
