11-11-2021 03:46 PM - edited 01-06-2022 03:59 AM
Apparently, this could be a porting issue and someone typed my number by mistake. Anyways, I got a text asking why I called them. Well it wasn't me. I checked on the public mobile usage history and there are no outgoing calls to the guys number. The person took a screenshot so I got the time stamp and the number was indeed my number. Could get I get mod to look into this so that my phone number is not stolen. Thanks
11-13-2021 08:54 PM
I use a VoIP service to make calls over WiFi or from my computer, and set it to send the caller ID of my mobile phone...
So if it's easy for me to "spoof" the caller ID of my cell phone, it sure as s**t will be easy for scammers to spoof whatever numbers they want to show too... Useful but unfortunately ripe for abuse...
11-12-2021 07:37 PM
We have been getting them too.
I’ve noticed that spoofers use the same area code and first 3 digit of our number.
11-11-2021 09:08 PM
Yeah it was actually the same area code now that you mention it. Darned scammer spoofers! 😠
Hopefully they sort it out.
11-11-2021 06:49 PM - edited 11-11-2021 06:50 PM
@Unsuitable wrote:Apparently, this could be a porting issue and someone typed my number by mistake. Anyways, I got a text asking why I called them. Well it wasn't me. I checked on the public mobile usage history and there are no outgoing calls to the guys number. The person took a screenshot so I got the time stamp and the number was indeed my number. Could get I get mod to look into this so that my phone number is not stolen. Thanks
I know it can be freaky to get a call and someone says "you just called me?", and you DID NOT.
It is a type of phone spam, fraudsters can call people making it look like they are calling from someone else's number. This way it makes the person receiving the call seems more likely to answer it.
Hopefully, they drop your number to use. It really is not a security risk and nothing Public Mobile can do unfortunately.
11-11-2021 06:46 PM
@ToMuchCatnip yes , it's a very common practice these day. In fact, you might have received some calls yourself, too. Didn't you have received some calls from very similar pattern to your own? Same area code and same first 4 digits. The scammer know people now not answer those 1-800 numbers any more, so, they try this spoofing and hope more people picks up the phone.
11-11-2021 04:17 PM
Same thing happened to me this week. Get a call from someone asking why I called em. Was like huh? Checked my call history and nothing. Not sure what is up.
11-11-2021 03:53 PM
It is likely a scam called Caller ID spoofing. Somebody is using your number to call other people. Nothing really can be done. Next time somebody calls, just tell them you did not call and it is caller ID spoofing.
Moderator or customer service agents are unable to really help.
11-11-2021 03:51 PM - edited 11-11-2021 04:01 PM
@Unsuitable no worry.. not porting issue. No need to contact CS Agent.
It is call Caller ID Spoofing
https://crtc.gc.ca/eng/phone/telemarketing/identit.htm
Very common these days, nothing you can do.
Those scammer /spammer trying to make their number more like "regular" number to fool people to pick up the call. They randomly generated the caller id number and it happens to be your number. No worry, it is not you being targeted
All provider are supposed to do something by end of Nov. Let see if this will really "kill" this practice , or at least lower the number
We (CRTC) asked telecommunications service providers to implement, by 30 November 2021, the STIR/SHAKEN framework which is a caller ID authentication and verification measure. It aims to certify the extent to which a given caller’s identity can be trusted. This will empower Canadians to determine which calls are authenticated, thus reducing the frequency and impact of caller ID spoofing on consumers.
11-11-2021 03:49 PM - edited 11-11-2021 03:51 PM
just ignore them and deleted and blocked...
if you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck.....
