Did you make sure Data Roaming is turned On? also make sure that your phone has service and is connected. if not call public to try to activate your phone
You can also verify that data roaming is on. I found that switching this off will cause issues with sending and receiving text. Also confirm the device is connected to the carrier network by going into settings> mobile network (may be different on your phone).
