$10 in Available Funds - Where it comes from?
Feellikedance
I just activated the SIM and got the funds. Is this from I enalbed Pre-authorization payment? Thanks.
8 REPLIES 8
Feellikedance
@hTideGnow I am a new user to PM and my friend referred me.
HI @Feellikedance  that is definitely Friend referrals.  But you are the one referring, right?
I think just say thanks and take the money.     🙂
Feellikedance
Yes, you are right!
"Your friend" means Me and "You" means my friend - Who referred me.
Feellikedance
Yes, I checked the payment histroy and found a RAF bill credit - Looks like I also got a "Refer A Freiend"? Thanks.
HI@Feellikedance   should be only your friend will get it and not you
But it could also be a 2x $5 payment if you are eligible for the special 5x $5 friend referral
Please go to Payment History, it should show clearly where the $10 comes from.  Check each entry there
Metal1967
@Feellikedance  You get 10$.. they get 1$ per cycle
Feellikedance
@Metal1967 Thank you so much for your prompt reply. I typed in my friend's referral code when I activating my SIM card. So, we both will get $10 funds? I thought only my friend will get it and I will not get it. Thanks.
Metal1967
@Feellikedance  Possibly your 10$ for the referral bonus
