Phone not working
Dave36
I received the text from Telus that I was switching said yes. The phone is still not working. I keep trying to submit a ticket but I always get an error. What do I do now.
8 REPLIES 8
Hi @Dave36
glad it works!
Dave36
Finally phone is working. Cs agent helped
@Andy85 wrote:
It usually could take some time for the cell phone service with the new provider to kick in. On occasion, it is quick. Other times, it could take a couple of hours.
How long has it been in your case?
It shouldn't ever take a couple of hours for the Public Mobiel service to start working.  The couple/few hours would only for incoming communications (when there's a number port).
Dave36
4 days
Dave36
Yes
Andy85
Chalupa_Batman
Did you reboot your phone?
Hi @Dave36
how long you replied?
Try reboot the phone first, then Reset All Networks
Test outbound calls, and  if you cannot make outbounds calls, please submit ticket with agent
if you can call outbound and just not receive inbound, then it is porting porting.  Call the porting team for update.  I will message you the number to call. Please check your Community inbox
