09-01-2019 01:30 PM - edited 01-05-2022 06:47 AM
My plan is active but not receiving callsb text. When trying to make a call it says no active long distance plan, which I do have
Help...
09-01-2019 01:56 PM
@willysr38 wrote:Thank you dabr. I topped my account by $2.00 and rebooted and it worked. Thank you
Happy it worked, and thanks for letting us know what worked too:)
09-01-2019 01:54 PM
09-01-2019 01:38 PM - edited 09-01-2019 01:40 PM
@willysr38 wrote:I have been on public for months ,didn't port number. Tried rebooting many times. Removed and reinserted SIM card. Still nothing...help
Then try the lost/stolen trick, log into your self serve account, click plans/add-ons, select phone lost, suspend service and log out. Wait several minutes and log back in and report phone found, resume service. Restart your phone.
One other thing to try is to top up your account with one dollar and restart your phone.
09-01-2019 01:37 PM
$40 unlimited canada.
09-01-2019 01:36 PM
09-01-2019 01:34 PM
More details may be helpful. New customer versus old? Which plan do you have? $10-50 minutes/text plan? Is it possible that you ran out of minutes or text?
09-01-2019 01:33 PM - edited 09-01-2019 01:35 PM
@willysr38 wrote:My plan is active but not receiving callsb text. When trying to make a call it says no active long distance plan, which I do have
Help...
If you just ported, the port may not be complete so you might need to wait a couple of more hours. Also it's a good idea to reboot your phone. Make sure you add +1 in front of numbers you are calling, although usually that message can be ignored and your call should complete.
