10-27-2024 11:06 PM - last edited on 10-28-2024 12:42 AM by computergeek541
Hi my phone is not compatible with ESIM so I can’t finish my setup of public mobile subscription, called different people and been on hold 2 hours no support . What is the proper step to fix the issue or get refund , since I can’t setup the service I am stuck .
one more thing I purchased physical SIM card from Telus but still no way moving forward
any help
10-27-2024 11:09 PM
HI @IG4821
one more step and you are all good.
just ask PM support agent to update the sim card number for you: Message them here:
10-27-2024 11:08 PM - edited 10-27-2024 11:08 PM
@IG4821 Get support to sim swap the number for you to the physical SIM card so you can complete the activation in the PM app
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
