Phone compatibility
rmulani
I have vivo v20 bought from middle east, the IMEI number on slot 1 of sim card is XXXXXXXXXXXXXXX, will it work with my phone
NOTE: Edited by srlawren to remove sensitive IMEI number
8 REPLIES 8
srlawren
@darlicious wrote:
@srlawren
Maybe you could just perform the edit for the OP instead. thx
@darlicious thanks, took care of it
.. thanks.. updated.
@softech
I believe you meant for the OP to edit the IMEI number but yes just as risky.
@srlawren
srlawren
@Anonymous wrote:
Yes will working 100% with public mobile phone compatibility
@Anonymous this is 100% incorrect.  At a bare minimum for use with Public Mobile, a phone should have both 850MHz (B5) and 1900MHz (B2) 3G bands.  The Vivo V20 only has the 850 and lacks 1900, therefore it is a very poor choice for use with PM.
@rmulani  You might not want to share the SIM  IMEI number,  this is dangerous.  This is a public forum and people can use the SIM number to do more than you thought.  Please click on the 3 dots of your original post and remove it
Both the South East Asia and Indian versions do not have too many compatible bands for PM.   While it might still work,  you want to have as many bands as you can so you won't get to area that you dont have good reception (or no reception at all).
Overall this won't be a great phone to be used in Canada.
@rmulani
Phone is not ideal with Public mobile.
Here is the specs:
https://www.gsmarena.com/vivo_v20-10435.php
3G bandsHSDPA 850 / 900 / 2100
4G bands1, 3, 5, 7, 8, 20, 28, 38, 39, 40, 41
It is missing the 3G, 1900 band
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
 @rmulani : I would pass on this phone. If you already have it then you may get some spotty reception.
visit Here  to you can see full information about your device.
TechnologyGSM / HSPA / LTE
SpeedHSPA 42.2/5.76 Mbps, LTE-A
Good Luck
