Phone compatibility
Lila17252
Hello, I would like to open an account with Public Mobile and have a Samsung A5, model SM-A520W phone. Would this phone be compatible with your service? Thank you
@Lila17252  yes you can and yes it is. Some Walmarts will not sell just the card without the activation but if you want to do everything there that's good!  Within 72 hours you'll have the 5gb data bonus and the 10$ credit on your account if you use a refferal code
Lila17252
Can I get a Sim card at my local Walmart and is the $40 plan 4.5gb data, unlimited talk & txt still offered? Thank you
GR
@Lila17252  yes it should work,   maje sure it's unlocked.  Don't forget a refferal code to get a 10$ credit on your new activation and if you sign up for a 35$or more plan you'll receive a 5gb bonus data
