Phone cannot send or receive calls
Northwestfrog
SMS is working, data is working.
Currently in Rivière Mattawin,  QC
Thanks for help
2 REPLIES 2
@Northwestfrog  - i do not notice any outages reported in your area:
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
Are you a new customer that has not been able to make/receive calls all along? Or, an existing one, that this just happened all of a sudden?
Try 1 or more of the below:
  • restart your phone
  • toggle into and out of airplane mode
  • perform a Reset of the device's Network Settings
  • move your sim card to another phone to see if calling works
  • manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) to see if calling improves
@Northwestfrog
Are you a new customer or are you using a new phone?  Also, if you set the network mode to 3g-only does it connect to the Public Mobile network?  Compatibility with that type of network is required for phone calls.
