03-08-2024 07:14 PM
One of my numbers ported in from Roger’s works fine except for calls coming in from other networks. it goes straight to voicemail but I also don’t get the voicemail. I can call those numbers just fine, they just can’t call me.
Service
03-08-2024 07:16 PM
You will need to re-initiate the porting process. I will send you the phone number via private messages. Check your inbox, click your avatar then click messages.
03-08-2024 07:15 PM
@Macademicz Sounds like the ported didn’t complete . Will private message you the porting team number .. give them a call they can re trigger the port request for you
