Phone can call out but cannot receive calls
08-18-2020 07:36 PM - edited 01-05-2022 12:49 PM
Just set up an old phone on public mobile. It makes phone calls and texts fine, but it seems to not be able to receive calls. It goes straight to voicemail.
Service
08-19-2020 12:09 AM
Have you tried calling from multiple numbers?
The reason I'm asking is one time I thought my phone wasn't receiving calls and it turns out it was because somehow I blocked my dad's cell number on my phone. I thought it was a network issue but it was a device setting!
Otherwise it's odd that the phone can receive texts (meaning the number is connected) but not calls...
08-18-2020 09:46 PM
@kittybooze wrote:Just set up an old phone on public mobile. It makes phone calls and texts fine, but it seems to not be able to receive calls. It goes straight to voicemail.
@kittybooze If you're still unable to receive calls, try rebooting the phone or powering off and removing your SIM, wait couple of mins and reinsert and restart your phone.
08-18-2020 07:40 PM
@kittybooze hi if you just ported your number this is normal it can take a few hours for port completion
