Phone call problem
Cecimay
Some phone calls can’t receive. When someone’s call , phone is not ring and go straight to voice mail even Phone is free to receive call
Is it he voicemail box that you set up at a previous carrier. If so, re-insert that carrier's SIM card to check the messages. The calls might have also be routed there.
TheSterlinger
Seems like porting error. I'll send you the porting department's number. Check your messages by clicking your avatar and clicking inbox.
@Cecimay  Did you just join PM and port a number in ? If so sounds like porting is not complete . I’ll send you the porting team number private message and they can re trigger the port request for you
