05-27-2022
08:32 PM
06-01-2022
11:54 PM
computergeek541
My phone number was switched and I cannot receive calls. How do I get my number back fron public Mobile
Service
05-27-2022 09:50 PM
Hi there, some more details would go a long way to diagnose the best course of action. If you answer the above questions it will help as there are a few avenues you could take depending on the situation
05-27-2022 09:19 PM
Did you port in a month ago? If so did your port complete? Is your old account still active or are you able to log into that account? If your port did not complete then after 30 days pm will reassign a phone number to your account so you can recieve calls. What happens when you call the number on your account?
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-27-2022 08:57 PM
05-27-2022 08:36 PM - edited 05-27-2022 08:37 PM
Hi @umck2006 can you specify if you have ported the number away from PM or if you are porting in the number into PM?
So, are you new customer to PM or you have been customer with PM but you are leaving and moving away your phone number to another provider?
[update]: Or did you just picked change number and you don't like the new number? You want the old number back? If that is the case, you can try to open ticket with CS Agent and see if they can.
At : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
