Phone Compatibility
06-01-2021 08:21 AM - edited 01-06-2022 02:12 AM
06-01-2021 02:40 PM
Yes, the iPhone 12 is compatible with PM.
06-01-2021 12:59 PM
Yes as long as you have Telus coverage in your area.
06-01-2021 12:00 PM
100% is will working
for public mobile phone compatibility
you have to put it a device brand for any phone to you can see all information,
you can visit here >>
WillMyPhoneWork.net - Check if your phone works on a network
following >> To find out if your cellular phone is compatible with our network, click HERE
visit Here to you can full information about your device.
Good Luck
06-01-2021 11:03 AM
@Lynney12 My friend uses this device and provider. You are good to go with this phone. Great compatibility with PM.
06-01-2021 08:27 AM
Yes, it will work.
06-01-2021 08:23 AM
Yes, it is compatible with PM.
06-01-2021 08:22 AM
yes it will. make sure it's unlocked
