Payment
jillea
Why am I not being able to add funds to my account? It’s telling me I can not add less than amount of my plan even though I have rewards and refer a friend discounts that lower my amount due.  I do not like these new changes
19 REPLIES 19
darlicious
@dust2dust @hTideGnow
$41.25 is the federal government's mandated price for a 2gb plan when it asked that mobile provider's reduce the cost of medium basket plans by 25% within two years back in 2020. $55 - $13.75=$41.25.
@hTideGnow- Apparently not. I haven't tried adding money. I run a balance. I haven't done the $1 trick for a long time.
Yeah that quarter is an odd duck. Marketing...hey I know...we can scrape an extra buck out of 4 clients to add to our billions of profits. Let's do it!
HI @dust2dust
so, the trick to add $1 is ok
But they should allow less than $1, the new plan has  $41.25, someone might need it  LoL
darlicious
@dust2dust
I agree....remember when they used to ask for volunteers to beta test? It seems only oracles beta test "improvements" to public mobile now and even their feedback is mostly ignored.
@a1foxes
This might help your situation....
https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-Make-a-Payment-or-Update-Your-Card-...
@jillea
You too!
darlicious
@a1foxes
Yes I tried unsuccessfully to make any kind of payment less than the plan amount and I couldn't find a way.
@hTideGnow
This also means you cannot reactivate your plan or attempt to reprovision your sim by adding a $1 manual payment.
jillea
So with my rewards it brings my total to 17 and than when you minus 5 dollars for refer a friend it brings it to 12 dollars my plan is 25 and is active due on 19th
jillea
Plan
jillea
Yes the minimum amount is the amount due for my pla ln
jillea
I don’t have a vehicle so it makes it difficult to get a voucher when prior to the changes they made it let me add funds prior to my due date and didn’t have to add what the amount due is
jillea
It always use to let me do it early I really dislike the new update
a1foxes
yeah thats about right, it wont let me fill in a smaller amount. I have 2 cards, which totals the right amount but it wont take them, it will only take the 48 minimum
HI @darlicious   I have a feeling the $20 minimum is more for the plan as the amount due is also $20.
Of course, would be nice if we can confirm from another person
darlicious
@jillea
WHAT?!! There is a minimum $20 payment?!! It used to be $1?!! This is just getting ridiculous!!
I think you can still get $5 vouchers at RCSS and $10 vouchers at london drugs.
@jillea wrote:
HI @jillea   Is your account current suspended?  And your plan is $25?    If those are true, PM would have already applied the rewards and hence your amount  is now $20.  Adding $12 would still just make it $17 and still not enough to reactivate the plan
if you do not mind, you can try to add the $20 in the account and see if it works.  Again, the extra fund would stay in the account for next renewal.
jillea
jillea
My payment isn’t due yet but I always add the funds early with rewards the amount due is 17 so minus the refer a friend it brings it to 12
dust2dust
Is your screen different than this?
I have sufficient balance to pay the plan and the account is active.
HI @jillea   There should be a radio box for "Custom Amount" and then you can enter the amount you want to pay
If still have problem, post a screenshot
darlicious
@jillea
What options do you have when topping up? Does it give you "other amount"?
