Payment
Suba
Hi
How can use my rewards to monthly payment.
Can you help me to pay from my reward
Thanks
HI @Mary_Chris
you got $75 redeemed? how long you have been with PM?
Mary_Chris
Hello!
Thats my question as well when Im still new😁On your account go to the my rewards sections, you will see an option that says browse catalog. Look through the catalog and you’ll find an option to redeem 15 points for a $15 bill credit. I got $75 redeemed! So happy. 😊
Mary
HI @Suba
yes it can help to lower your bill
but you have wait til  you have 15 points.  Then what you need to do is to login My Account, Rewards, click Rewards Portal.  Then you redeem 15 points by going to catalog and pick $15 bill credit.  Redeem it and it will be in your My Account within hours , showing up as Available Fund.  PM will then use it for your renewal
@Suba  If your in old rewards you do t have to do a thing , but if your on points rewards you just go to your points portal in your account and once you have 15 points you can redeem $15 off your bill or buy add ons and sometimes enter phone draws , check out the rewards catalogue
Points rewards portal view catalog
JRod
@Suba
will13am
@Suba , this help article explains all about how to use the rewards.
https://www.publicmobile.ca/en/on/get-help/articles/redeeming-public-points
