10-31-2019 03:52 PM - edited 01-05-2022 09:36 AM
11-01-2019 08:17 PM
This happens to me twice already, both of the times I have to call *611 to enter the pin number on the receipt. After entered the pin, my balance in my account on the website almost right away.. hope this helps..
11-01-2019 01:18 PM
Usually when this happens to me I just email the moderators a picture of my vouchers and they can manually add on to your account.
10-31-2019 07:26 PM
@Chadbennett1989 wrote:Can you get locked out of your account if you submit invalid voucher numbers? I was enetering the wrong number by accident through calling 611 and now when I enter the correct PIN number it is saying it cannot process my request
@Chadbennett1989 Did you retry after waiting a while and did it finally work?
If you are still unable to load your voucher and make a payment, then you need help from moderators, so submit a ticket to moderators via SIMon here: https://publicmobile.ca.ada.support/chat/
10-31-2019 05:41 PM
10-31-2019 05:00 PM
@Chadbennett1989 wrote:What do you do when it is not allowing you to apply your payment vouchers
Wait for a day and try to deposit the PM topup voucher again.
Some store, like Shell gas station, will activate the PM voucher rgiht away. Within 30 minutes, you can add it to your account.
10-31-2019 04:39 PM
@Chadbennett1989 If you can't add the vouchers using both selfserve or by calling 611 the best to submit a ticket with the PIN number and ask PM to add them to your account.
To submit a ticket to Public Mobile do the following:
10-31-2019 04:10 PM
No reason for it not working at PM end, try from a different browser or just wait couple of hours. Good luck!
10-31-2019 04:03 PM - edited 10-31-2019 04:18 PM
It's been known that some vouchers aren't "activated" for several hours after the actual sale. Try adding it by calling 611.
Wait until 24 hours has elapsed...if nothing happens you'll have to contact a moderator. Click the ? in lower right side of screen to start process of moderator intervention. Type 'payment voucher won't work", then follow instructions.
10-31-2019 03:59 PM - edited 10-31-2019 04:03 PM
Try clearing your cache and cookies and also try a different browser. Also sometimes waiting one hour can help.
You can use vouchers for payment, log into your account and click the payment tab and then click 'make a one-time payment' and follow the prompts using the correct 12 digit code on the voucher.
You can also try dialling 611 on your phone.
