Payment not working
441_
I have tried adding a payment card since the website has changed and everytime it tells me “oops! Something went wrong, try again later”
my plan resets tomorrow and I can’t pay, why won’t they take my money🤦🏻‍♂️
Dunkman
@441_
There was a known issue with the payment system, but supposedly it was cleared up earlier this morning.  As mentioned, first check to make sure that you were not billed already.  Try again, but maybe with a different web browser, clear cache or incognito mode.  Or a different device.
If still issues, let the community know.
CountyDownIeUk
That used to happen before. You would have thought it would have been fixed.
I have had that error happen too .....and the payment went through.
So before you do as others have suggested, check your balance.
HI @441_   try to use Incognito mode or use another browser and see if it works.
You can also try on another computer
If still not working, please open ticket with CS agent today since you need it fixed quickly for payment tomorrow
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
RossN
@441_ Hi try using a different browser in ingognito or secret mode if nothing works contact a customer service agent so they can manually add it
1. you can open a ticket through Simon here https://publicmobile.ca
2. alternatively you can private message them here
