3 weeks ago
3 weeks ago
hi @A-LO
you can only download bills for the last 12 months. Since it is April now, you won't be able to download bills from Jan to Mar 2025 yourself
For the 3 bills, PM support agent can help to prepare them for you. Please submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
3 weeks ago
if you cannot find the bill you want to download from My Account -> Payment History, then you will have to ask PM to send you the older one
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
