Payed twice for one payment
Josh9299
I upgraded my subscription to the 40 dollars for the 20 gigs and it charged me 2 times.
8 REPLIES 8
Josh9299
It's all sorted out.
Josh9299
I tried to change my plan the first without wifi so when I excepted the change it shut my service down so the payment went through but my plan didn't change over when I went on it through wifi, so I tried again and it charged me again and then my plan changed.
HI @Josh9299
does it charge you twice the $40? or did it charge you old plan price, then you use Change Now when you make plan change?  if you did that, it is normal for PM to charge you again.  Charge Now means PM will start a new cycle and hence charge you new plan amount, even your old cycle just started not many days ago
If you are in doubt with the charges, submit a ticket with CS agent:
Josh9299
I waited a few days and I checked again and all all 2 payment went through. I should get a refund for the 2nd payment that wasn't supposed to go through.
@Josh9299  Give it a day or two . Only 1 charge should go through. Otherwise then contact support if not
Josh9299
There still both pending on my credit card.
@Josh9299  Check credit card is one charge pending and the other posted ? If so the pending charge should fall off . Also check your my account  in available funds for the difference . If not there and both charges posted please
Message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
