05-11-2021 02:27 AM - edited 01-06-2022 02:40 AM
I am unable to pay for my bill its showing number not found?
05-11-2021 06:04 AM - edited 05-11-2021 06:04 AM
@Gazal wrote:They are asking for 4 digit pin i dont know that please help
@Gazal have you ever signed up for a Self Serve account? If not, it may be a good idea to do so, you can do that here: https://selfserve.publicmobile.ca
As for your PIN, is sounds like it used to work, but now it does not?
If so, I would contact the Moderators. Only the Public Mobile Moderators can change your Account PIN.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
Type "Account PIN issue"
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
05-11-2021 05:04 AM - edited 05-11-2021 05:05 AM
Ask for a voucher that will cover your plan amount. For example if you are on the $40 plan get a $40 voucher and you will pay $40+taxes. The reciept will have the amount + taxes. The voucher will just show $40.
Then dial 611 on your phone. Press (1) then (1) again and then add the 12 digit code. It will tell you that you have added funds to your balance and send you a text saying you have successfully added funds to your account.
Here is a pic of a 7/11 voucher....as you can see they also have $25 vouchers.
You enter the 12 digit PIN #
05-11-2021 04:51 AM
Ask the cashier for a public mobile voucher. They usually come in $10, $20, $40, $50,$60 and $100 amounts. You will get a reciept and the voucher. Make sure you get both because they look very similar but the voucher will have a 12 digit code on it.
There is an example in the voucher catalogue link i posted.
05-11-2021 04:40 AM
What are the cost for the vouchers?
05-11-2021 04:25 AM
So like for 7/11 i ll get the voucher so will it have some amount or do i need to add some money into it?
05-11-2021 04:20 AM
@Gazal You don't need extra in the account but some stores only sell vouchers in set amounts.
05-11-2021 04:12 AM
So after the voucher i ll be able to pay for the mobile or do i need to add some value in the payment voucher
05-11-2021 02:54 AM
Heres more more info on vouchers that may help...
05-11-2021 02:50 AM
Is your renewal tonight? You can buy a voucher that you can load onto your account via 611 with no 4 digit pin code needed.
Vouchers purchased at London drugs, SDM, 7/11 and Shell gas stations are immediately valid so you can load them right after you buy them thru 611 on your phone.
RTP ( real time payments) are available at Canadian Tire gas bars ( not the store) and Mobil gas stations for a $1 fee.
You can pay online thru recharge.com and ding.com for a slightly larger fee.
05-11-2021 02:36 AM
05-11-2021 02:36 AM
You can do that by opening a ticket to contact a moderator but first...
05-11-2021 02:35 AM - edited 05-11-2021 02:35 AM
@Gazal : What happens when you dial 611? Are any services working? Calls in/out? Texts in/out? Internet browsing?
05-11-2021 02:32 AM
What if i forgot that?? I used to go to a store there the girl used to ask me for my number just and used to pay but now when i went she told that its telling that ur number is not found? I want to reset my email my password my security question everything
05-11-2021 02:29 AM - edited 05-11-2021 02:29 AM
The only way you can pay before 9am eastern tomorrow morning is by dialing 611 on your phone and adding a voucher or with the credit card on file if you know your 4 digit account pin code.
