06-03-2022 09:37 AM
I put the wrong password many times and got blocked. I need to rest my password
06-03-2022 09:52 AM
Hi @Puplic519 Please open a ticket with PM CS Agent at
To open a ticket with PM CS Agent. Click on the Bubble or directly at : https://publicmobile.ca/chatbot.
Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
06-03-2022 09:48 AM
@Puplic519 @Hello if it continues to lock you out after following above suggestions you will need to open a ticket through Simon to speak to a customer service agent type in password reset they will help you Click here
06-03-2022 09:47 AM
No I don’t know the password I forgot it and I need to reset pleas because I want add data ASAP I need it now
06-03-2022 09:39 AM - edited 06-03-2022 09:39 AM
I'm assuming you know the password? You can wait 15 minutes and you'll ne allowed back in.
