Add ons
Itzbharper95
I accidentally put a add on i cant use. Can i change it from us to canada??
HI @Itzbharper95
CS Agent likely able to swtich the add-on for you.  Please open ticket at : https://publicmobile.ca/chatbot.
Follow this to get to ticket open screen quicker:
  1. First Type "Wrong Add-on / plan purhcased"
  2. Then click "Contact Us"
  3. and then click "Click here to submit a ticket"
  4. you will then direct to another page to open ticket.
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
darlicious
@Itzbharper95
Contact customer support and explain the honest mistake. They will remove the add on and replace it and/or credit your account.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
Sorry, but add-on purchases are non-refundable.  A CSA might be able to help but officially, they don't have to, but mY on a case by case basis.
