Password reset error
CR1974
Hello
I am trying to reset my password but it says error resetting password try again later.
Someone please help
2 REPLIES 2
Moved:
HI @CR1974   try clearing the cache and restart the browser.
Also, try to use Incognito mode
If issue persists, please open ticket with CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. First type: "Forgot log in information"
  2. Then Click "Contact Us"
  3. Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
