Partial Porting Purgatory
magimug
Has anyone else tried to port from Virgin Mobile with sim registration and ended up in limbo?
I did that with my first phone and am still waitng (I did send a message to a moderator)...I do have data
My second sim registration...I chose a PM number and then ported the Virgin number without any difficulties and all within a couple of hours...Sorta wishing I did the same for the first one
2 REPLIES 2
surf99992001
No worries, the mods will fix you up, or they will send your issue to the "porting department" to solve the issue.  From acknowledgement from mods, my issue got fixed up within 24 hours.
Good Luck!
jheili99
hi..
at the moment a common problem caused by various reasons...
e.g: info you provided do not match 100% exactly as used for Virgin........PM system sluggish.....etc...
just private message a moderator again and they will get to you hopefully faster this time..
@Saray_O
cheers
