04-06-2019 04:07 PM - edited 01-05-2022 04:12 AM
I have paid for the US roaming bundle. Shows I've paid twice. Wanted only one bundle. Nothing works. This has happened to me once before. Tried dialing *611 and getting "experiencing technical difficulties.
What now PM?
04-06-2019 07:17 PM
I’m having same issue, shows that I have the plans but can’t get anything to work
04-06-2019 06:44 PM
It seems that you have to fund your account prior to adding the bundle even though the process let you choose the add-on and them pay. Probably should make this clearer on the website to avoid confusion.
04-06-2019 04:34 PM
@sgk - Do you see the US roaming add on in your self serve portal? If you paid twice, you should still have an account credit for the second one. Also, is your network set to automatic? If you locked into PM network, you must switch to automatic, or manually select one of the PM partners (AT&T or T-Mobile).
04-06-2019 04:31 PM
@sgk wrote:I have paid for the US roaming bundle. Shows I've paid twice. Wanted only one bundle. Nothing works. This has happened to me once before. Tried dialing *611 and getting "experiencing technical difficulties.
What now PM?
Verify your phone settings at well. Ensure that you enable roaming.
04-06-2019 04:11 PM
