PUK
Mikey207
I need my PUK. How do I figure that out for a Samsung A32. Help. I desperately need to access the information on it with a quickness. Any help would help. Thanks
2 REPLIES 2
slusagm
PM can help if it is a sim card lock and sim card PUK is needed
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
@Mikey207  If it’s a sim PUK support can help
send  a  private message   To CS_Agent
