PUK
Allyson03
How can I know my PUk code? I recently transferred from other courier to public mobile, my connection is still … and I cant contact anyone cuz my sim is locked.
1 REPLY 1
@Allyson03
what was the exact error message? Depends on the message, you have to ask the PUK code from different places.  Sound to me you need a carrier unlock PUK
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
          You have to ask the carrier where you got the phone from for the carrier help unlocking it.
           (Sorry, for this particular issue, PM support would not be able to help)
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK."
      call  Samsung 1-800-726-7864 for a master unlock code.
      The only info you will need to provide is the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM  Card, SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
         open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
          or use this direct link to open Chatbot ticket:  https://urlshortner.tiia.ai/Oyn1L6
            **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you
there.
