PORTING MY NUMBER
9059385764
I’m still with my original provider
9059385764
Yes everything worked out.
HI @9059385764
I hope the username is not your phone number, you may want to ask PM support agent to change it.  This is a community and you don't want your phone number posted in public
for the porting.  It looks like you are porting form Bell Canada and it is a landline.  Please note porting from landline takes as many as 7 days. So, if has not been a week yet, it is ok.  But the day your landline stops working, it will mean the port is completed
slusagm
Porting in? Did you receive a text from your old provider and did you reply Yes within 90 mins?
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
