10-26-2016 04:27 AM - edited 01-04-2022 03:44 PM
Hi all,
Today is the start on my second 90 day term. I have autopay activated. Recieved SMS saying 90 days expiring please pay or if auto pay enabled do nothing.
I future dated an account change to a lower fee, as heading out of the country.
I logged in to the the account and it says:
Oct 26, 2016 | Automatic Top-Up/Réapprovisionnements auto. | $99.00 | $111.00 | |
Oct 26, 2016 | Reward - Refer-a-Friend ($1 per active friend) /Récompense - Référez-un-ami (1 $ par ami actif) | $6.00 | $12.00 | |
Oct 26, 2016 | AutoPay Reward | $6.00 | $6.00 |
The phone as of right now is still working.... data shows on hold but 6mb used
So I'm not sure if its a glitch, and should just wait and it resolves itself, or what I else I should do, I don't want my Credit card get charged a second time.
thanks for any help
10-26-2016 10:14 PM
@Mary_M Thanks for the quick work. All is working fine now. Hopefully PM is able to fix this glitch in the future.
10-26-2016 02:24 PM
@mimmo I hope @Mary_M has you fixed up ASAP.
10-26-2016 10:11 AM
Hi @Mary_M,
Thanks for quick reply, Just an update, the account curently went completly suspended, Currently can't make or recieve calls.
Dom
10-26-2016 09:33 AM
Hey @mimmo
I have received your private message.
Hang tight! I'll fix this up for you and I'll respond shortly.
Thank you,
Mary
10-26-2016 06:01 AM
Hey @mimmo this is a known glitch that when you change a plan, it doesn't process properly. Just sit tight for now. You're going to need a moderator to make an adjustment on your account. Someone should be online by 9:00 am eastern time.
10-26-2016 04:53 AM
Also the My Account page states:
