03-15-2018 12:05 PM - edited 01-04-2022 03:44 PM
03-15-2018 02:41 PM
the selfserve portal should give hints to what happened.
03-15-2018 12:11 PM
@wooge, Does you self service portal show minutes remaining in your LD add-on? Any chance it was used up?
If you think it is a system issue, please send a private message to the moderator team so that they can investigate. Be sure to include your account number or phone number, as well as your account PIN in order to speed things up a bit.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
