09-14-2024
04:59 AM
09-14-2024
07:22 AM
computergeek541
The PM app won't load so I can activate my plan. I enter email and password and the app just shows the spinning circle. I have uninstalled and installed over a dozen times. Any suggestions?
09-14-2024 01:19 PM
if you already got charged, support can help to complete the suscription (choosing numer/porting and finalize the activation). Please message them here
09-14-2024 12:03 PM
Thank you softech (Oracle). I have a samsung S24. Yes I do have another phone (samsung A51). I downloaded the app to that phone (A51) and it worked. However I don't want the PM plan on that phone.
09-14-2024 07:38 AM
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
09-14-2024 07:12 AM
what phone do you have? you have another phone that can help with that?
Since server could be down for maintenance in late hours (or early morning hours), I suggest you to wait till after 9am. Uninstall the app one more time and reinstall. Use another email address this time to create another account and try it again. Let us know if any success with that
