PIN blocked contact service provider
AB31dv
I tried to change my 4 digit pin and failed now i am totally locked out. Phone will not open to keypad.???
2 REPLIES 2
@AB31dv
Do you mean the phone will not open to opening screen?
It sounds like a phone issue if this is the case.
slusagm
Sim card PUK needed? Ask PM and they can provide.
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
