Outgoing messages not working
Vheek
I just ported my number from Rogers to Public Mobile. Everything is working but the outgoing messages. They are not being received by any recipient. Looking for assistance.
My Rogers account number is below, just in case you need it.
7 REPLIES 7
DRS63
Had same issue read earlier to  try a different app  to text. Went to google message and same started  working. Returned to previous text app samsung and all is functioning well.
Vheek
Yeah. Still not working. I'll submit a ticket. Thank you for the help.
Vheek
Done. Removed.
Thank you for the warning! I appreciate it.
HI @Vheek
I would uninstall and reinstall Google Message (or if you are not using Google Message yet, download and use it as the default message app)
If same, submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
Vheek
Yes. Inbound/outbound calls work. I can receive messages as well. Only the outbound messages are not recieved by any recipient.
Phone already rebooted. And messages app cache and data were cleared. Same issue.
Socrates8567
Please remove your number at the top right corner arrow. Posting your phone number on the Public Mobile community forums—or any public forum—is not advisable.
When moving a number from Rogers, outgoing message failures typically indicate that the porting process is in a "stuck" or "limbo" state. While your data and outgoing calls may work almost immediately, SMS and incoming calls often take the longest to fully migrate. When you initiated the transfer, Rogers should have sent an SMS to your original Rogers SIM card asking for authorization. Sometimes the device retains legacy configurations from Rogers that interfere with Public Mobile's SMS gateway.
Android: Settings > General Management > Reset > Reset mobile network settings.
iOS: Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings.
hi @Vheek inbound calls work? please confirm
also, make sure you remove the Rogers sim card, or disable the Rogers eSIM.  Check again and make sure PM sim is enabled and set as Primary
then Reboot phone and click Reset network settings and test again
if it still fails, and if you have an Android, clear the Message app cache and clear data on the Message app
