Outgoing calls
Royregan
I can not make outgoing calls but can receive incoming. How do I fix this?
Royregan
Calling out has never worked . I can receive calls .,can text , data is working fine . Have rebooted ,nothing seems to work ..suggestions ?
Dunkman
@Royregan
Did calling work before?  What about text and data?
Also, try add prefix  1 or +1 in front of the area code of your call.  Other customers have had similar issues. Might be related to the roll out of VoLTE
@Royregan  First start by rebooting the device if you haven’t already and see if that helps . You can also try resetting your network settings also
