Outgoing calls not workibg
bjhiwvhwipviwhj
Incoming calls work fine but can't make outgoing calls. Get error 6UT1 The number you have reached is not in service.
2 REPLIES 2
hairbag1
@bjhiwvhwipviwhj
if you have the current $15 plan...maybe you've run outta your 100 minutes. Log in your laptop and try this...
Hi   @bjhiwvhwipviwhj
I saw couple customers complained this today.  Possibly a PM network issue. Please submit ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
