08-11-2020 01:23 PM - edited 01-05-2022 12:29 PM
Hi,
I have a limited 100 min Canada wide talk plan with other default services. Though I do not make many outgoing calls but all allowed 100 mins have been used. After checking my usage history, I came to know by default an outgoing call is going to 6475804001 which seems to be some voice call number. I would like to stop this and why is it being charged as outgoing call?
08-11-2020 03:43 PM
@harshsangal Seems you are in the old $15 plan. The new $15 plan has unlimited incoming calls and 100 minutes outgoing call. You can change your plan soon and get the benefits of unlimited incoming calls in your next payment cycle. Don't activate the plan today as they will charge you again.
Your voice mail: There is no way to delete your old voice messages in the system. So it would be better to inactivate the voice message function. I did that for mine. If you need to call, you have to buy the $5 for 500 minutes plan in the meantime.
Hope that helps!
08-11-2020 02:50 PM
Also if you don't want to receive any voicemail you can specify if your forwarding options to forward to a random USA number, after missed/declined/unavailable call the forward will fail and call will disconnect, the caller will only hear a click.
08-11-2020 02:46 PM
I have a great way to preserve your calling minutes when you know the call will be long or you may have to wait.
Install fongo get a free account with free calling and free forwarding.
When you have to make such a call, you use fongo to call your own number which is incoming hence unlimited, then you transfer your fongo call to desired destination, that moment fongo disconnects. It uses less than 0.1 megs and you have 250 megs if you don't have access to WiFi.
As a bonus you can also specify in your forwarding to forward to your fongo number instead of public mobile voicemail. Set your fongo to ring only once. You will receive all your voicemails at fongo and can also have fongo forward a copy to your email. You can either call in using fongo or you can get them in app kinda like visual voicemail. If there is one you'd like to keep, email is great
08-11-2020 02:18 PM
Thanks. Seems to be nice idea.
08-11-2020 02:13 PM
@harshsangal if you want to disable voicemail follow these instructions
credits to srlawren
dial into your voicemail and log in with your PIN.
In the main menu, press 3 (manage greetings),
then 4 (manage extended absence greeting),
then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
Then press 4 to turn on extended absence
Finally, press 5 to dissallow anyone to leave you a message.
08-11-2020 02:12 PM
Thanks. I don't really use voice mail so would like to disable it.
08-11-2020 02:08 PM - edited 08-11-2020 02:09 PM
@harshsangal wrote:Thanks for the responses. I don't really retrieve any voice messages but still it is counted as outgoing calls. How can I disable this?
The usage details record this as an ougoing call when sonmeone gets forwarded to your voicemail, but it doesn't count as outgoing minutes used.
08-11-2020 02:02 PM
08-11-2020 01:55 PM
@harshsangal , as already mentioned, 6475804001 is the voicemail number for the GTA. It is mentioned in the plan offer details that calling voicemail will consume minutes. It is a great idea to have a $5/500 minute add-on as a fall back.
08-11-2020 01:30 PM - edited 08-11-2020 01:31 PM
@harshsangal wrote:Hi,
@harshsangal That is PM's voicemail number and you don't get mins deducted unless you retrieve messages from voicemail. You are simply being notified that there is a message being left.
It's a good idea to buy the $5/500 mins add-on to supplement your 100 outgoing mins. These mins can be utilized when you've depleted plan mins and any mins left will keep rolling over every cycle until depleted.
08-11-2020 01:28 PM
Yes, the xxx-xxx-4001 number is the voicemail number. But the minutes used by your caller to leave a message on your voicemail will not counted as your outgoing minutes.
But if you use your phone to get your voicemail will count toward your 100 outgoing minutes.
08-11-2020 01:27 PM - edited 08-11-2020 01:32 PM
@harshsangal if you check your voicemail. The xxx xxx 4001 number it counts towards your minutes. Instead either use Google hangouts and Google dialer combined or add the TextNow app and use it over WiFi to make/ receive/ send calls and texts within Canada and to and from the US for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter it followed by # - and you are in your voicemail account - Hang up when you are finished. No minutes used.
