07-17-2020 01:47 PM - edited 01-05-2022 12:29 PM
I cant connect to the network to use my data when i am outside the WiFi area. I have shut off my cell and taken out the SIM CARD. Still not working. Bills are paid. Using same phone for 1 1/2 years. I have also tried the APN...all looks ok on that front. Still NO INTERNET CONNECTION. What else can I do??? Please HELP ME!
07-17-2020 04:23 PM
Check your APN, cannot be Telus, use Public Mobile.
From SIM to view your APN setting.
Good luck!
07-17-2020 03:32 PM
Network Reset worked. Thank You!
07-17-2020 03:25 PM
@bernamyr are any of your other services working, calls/texts?
07-17-2020 03:18 PM
I have DATA left. Used 161.779 MB and 862.221 MB left. Thank You!
07-17-2020 03:17 PM
@bernamyr wrote:I tried turning phone off totally. Then tried turning phone off and taking out SIM CARD. Waited about 5 min to put SIM card back into phone. Turned it on but still NO INTERNET CONNECTION.
1. It is time to test your PM SIM card on another phone from friend or family to determine the problem is your phone or PM issue.
2. Configure your phone to auto switching between 3G and LTE 4G signals. Location without 4G, your phone will switch to #G and vice versa.
07-17-2020 03:09 PM
@bernamyr here's how to check if your data is enabled.
If it isn't, switch it on and try sending an mms/ picture text message. If that works, your APN settings are correct and you should be able to surf the intwrmet. Stay safe.
07-17-2020 03:03 PM
07-17-2020 02:58 PM
Where do I check to see if DATA is turned off inadvertently?
I have a Samsung Galaxy J3.
Still showing NO CONNECTION.
07-17-2020 02:42 PM
https://www.google.com/amp/s/m.gsmarena.com/samsung_galaxy_j3_(2018)-ampp-8928.php
OP might have this version
07-17-2020 02:36 PM
No @bernamyr enable data and try sendimg an mms text message. If you can, your APN settings are correct. Stay safe.
07-17-2020 02:34 PM
@bernamyr your phone doesn't seem to have the required LTE bands.
https://www.gsmarena.com/samsung_galaxy_j3_(2016)-7760.php . In areas with only 4g, you will not be able to connect to the internet. You will still be able to send and receive mms messages. Have you ever gotten an alert on that phone? Thanks.
07-17-2020 02:33 PM
Some things are the same but some are different. Should I change the different things to look like what you sent me?
07-17-2020 02:26 PM - edited 07-17-2020 03:34 PM
@bernamyr reset your network settings and restart your phone if it doesn't automatically do so.
Stay safe.
07-17-2020 02:26 PM
Try removing and reinstalling your sim card. Try rebooting your phone. If you have another phone try swapping the sim.
07-17-2020 02:23 PM
Samsung Galaxy J3
07-17-2020 02:14 PM
@bernamyr check to see if you have inadvertantly turned data off. Enable it and try sending an mms message. If it works, your APN settings are correct. If it doesn't, try the network reset as suggested by @kselmak . Also, what's the make and model of your phone as asked by @gpixel? Do you still need help? Or is your phone working properly now. Thanks. Stay safe.
07-17-2020 02:12 PM
@bernamyr Post a screenshot of your APN settings if you have an Android phone. If you have an iPhone reset your network settings.
07-17-2020 02:05 PM
Do your settings in your APN for PM look like this?
07-17-2020 01:50 PM
@bernamyr what's the make and model of the device?
07-17-2020 01:50 PM
Try network reset
How much data do you have left?
07-17-2020 01:49 PM
@bernamyr hi have you checked your self serve do you have any data left?
