11-16-2022 05:45 PM
November 4. 7:43PM. A outgoing call got charged 38 minutes twice.
Service
11-17-2022 10:34 AM
Ticket submitted. Thanks everyone...
11-17-2022 10:18 AM
38 minutes @7:43PM x2.
How to contact a CS_Agent?
11-16-2022 08:12 PM
I am assuming your are on the $15 plan since the other plans have unlimited outgoing calls.
Contact a CS_Agent to look into the double outgoing charges and have it adjusted.
11-16-2022 07:56 PM
I presume you're on a minute limited plan which is prompting your inquiry.
Can you screenshot the line items showing a double entry? (masking any personal information otherwise visible in the screenshot)
I wonder if it's possible you're viewing the line item on the bottom of one screen, then at the top of the next page and it may be one in the same line items. Just a thought...
11-16-2022 05:50 PM
What plan are you on?
