02-10-2025 07:35 PM
I cannot make outbound calls
02-10-2025 07:42 PM
@ABallard wrote:I cannot make outbound calls
Hello @ABallard
You're going to have to share way more information than that if you require help. Stuff like, are you a long time customer or just joined. What phone you're using, what part of Canada are you in.... any info to help us help you.
02-10-2025 07:38 PM
You just joined? Make sure you remove the old physical sim card or disable or delete the old esim
next, reboot phone and reset network settings
