11-03-2021 10:08 AM - edited 01-04-2022 05:17 AM
Hello, I have
But when calling a store local to me, less than 8 minutes away in the same town, it is telling me I am out of minutes? Have I misunderstood what unlimited canada-wide talk means?
11-03-2021 01:07 PM
next time if is happened
do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
To get the obvious out of the way...you used ( +1 or 1 ) in front of the any area code,
for Example long distance in canada or from USA,, Add (+1 or 1 ) in front of the any area code,
1416xxxxxxx,
or
+1416xxxxxxx,
both is will going through your call...
Good luck and enjoy the service.
11-03-2021 10:15 AM
@Pladdicus no worry.. it happens. 🙂
11-03-2021 10:14 AM
Thank you, it did work. I also checked and I guess I dialed the wrong number and it was not local, haha. Oh well. Thanks!
11-03-2021 10:10 AM - edited 11-03-2021 10:10 AM
@Pladdicus wrote:Hello, I have
- - Unlimited Canada-wide Talk
@Pladdicus Yes, this is a common system glitch but don't worry. This issue might come up occasionally.. Just try to add a 1 in front of the 10 digits you are calling or reboot your phone. It should work after without issue.
