08-19-2016 07:12 PM - edited 01-04-2022 03:04 PM
08-20-2016 09:46 AM
Hello @Eduprince91
Thank you for porting on the community.
The plan you are referring to actually costs 120$ for 90 days. It includes 6GB of data, provincial wide talk and global text. If this is the plan you want, please send me her phone number by private message and I will take a look into it.
Mary
08-19-2016 08:17 PM - edited 08-19-2016 08:19 PM
@Eduprince91 Unfortunately errors happen now and then. You will need the assistance of one of our moderators; @Shazia_K @Mary_M who have left for the day. ![]()
You will need to send them some information by private message. If unfamiliar with this feature, you can review it here: Private Messages - viewing and creating. It will speed things along if you can check in from time to time during "Ontario business hours" tomorrow.
If are porting a number your old sim will keep working until the port completes. Do not cancel your account; it will close automatically when the port completes.
Meanwhile, if she needs to make phone calls try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
Hang in there.
08-19-2016 07:58 PM
@Eduprince91 There is no $40 for 90 day plan; did you mean the $120 for 90 day plan?
08-19-2016 07:33 PM
It is you that have to select the plan during activation or when you want to change your plan. Depending on what exactly happened, staff member will know what to do. One of them will be in touch with you tomorrow.
08-19-2016 07:31 PM
Hi @Eduprince91
This will need a moderator to have a look. One will be back online in the morning, hang in till then. @Shazia_K @Mary_M
08-19-2016 07:24 PM
