Ordering a New SIM Card for iPhone 5c
03-18-2016 03:24 PM - edited 01-04-2022 12:51 PM
I got a new iPhone recently and I wish to use it with my current PM Plan however I need a new SIM card. How can I get a new SIM that fits the phone without changing my plan? I tried navigating through the website and the forums, but to no avail. Even the contact us section said nothing... Help Please!!
Phones
04-04-2016 04:19 PM
@eathansohma I just wanted to add that you may not need to get a new SIM card. If your old phone uses a standard or micro size SIM, you can just push out the nano in the middle and use it for the new iPhone 5c.
If you need a new SIM regardless, you can order it here https://store.publicmobile.ca/
03-18-2016 03:33 PM - edited 03-18-2016 03:33 PM
Hi,
Just go to the homepage, and click Order a SIM card. It's a free tri-punch card. You will receive it in 3 to 7 business days.
BTW, changing your SIM card in no way affects your plan, and vice versa. Each is separate from the other.
I hope that this reply has addressed your concerns.
