Oops so I'm dumb
11-21-2016 11:41 PM - edited 01-05-2022 12:48 AM
Anyone else click on the wrong data amount.
I'm sure the answer is to pm a mod, but they aren't even answering or opening messages
Fml ...
Service
11-22-2016 04:45 AM - edited 11-22-2016 04:46 AM
Don't worry, they will fix it as they have for others who did the exact same thing. You just need to contact them and be patient. With the promo over I'm sure it won't take long to fix at all, the backlog should be easing.
11-21-2016 11:51 PM
11-21-2016 11:49 PM
Is your old sim still active? many are if the port isn't completed and you can always put it backin and use it until it gets cleared up
11-21-2016 11:47 PM
I clicked on the wrong thing, my mistake, i doubt they will fix it. Hopefully they eventually will at least read my other messages about the port problems. Fingers crossed...
11-21-2016 11:46 PM - edited 11-21-2016 11:47 PM
Pretty sure they will take care of you it maybe a few weeks before they have time to look at it as it is a minor issue compared to now service for some members
11-21-2016 11:45 PM
11-21-2016 11:43 PM
I the mods should be able to fix that, as long as you did activate yesterday?
11-21-2016 11:41 PM
