06-10-2019 10:53 PM - edited 01-05-2022 05:19 AM
Hi.
I am planning on purchasing the Oneplus 7 Pro. Can someone please confirm/ let me know if it will work with Public Mobile? I tried using the "Check your phone's compatibility" on Public's webpage, but the 7 Pro is not on the list. Not sure if its because it had only been released in the past month.
The connectivity specs are:
LTE
4×4 MIMO, LTE Cat. 18, DL 5CA, UL CA, Supports up to DL Cat18 /UL Cat13 (1.2Gbps /150Mbps), depending on carrier support
Bands
FDD LTE: B1,2,3,4,5,7,8,12,13,17,18,19,20,25,26,28,29,30,66,71
TDD-LTE: B34,38,39,41,46,48
UMTS: B1,2,4,5,8,9,19
CDMA: BC0,BC1
GSM: B2,3,5,8
https://www.oneplus.com/ca_en/7pro?from=head#/specs
Thanks!
06-10-2019 11:21 PM - edited 06-10-2019 11:23 PM
If your phone is missing from the list of devices, leave them a note here so they can keep on improving our compatibility checker. Click this to message them
-Public Mobile Community Team
06-10-2019 11:07 PM
The phone should work on PM.
Public Mobile uses the following frequency bands:
Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
06-10-2019 11:05 PM
@BarbaraWong wrote:Hi.
LTE
4×4 MIMO, LTE Cat. 18, DL 5CA, UL CA, Supports up to DL Cat18 /UL Cat13 (1.2Gbps /150Mbps), depending on carrier supportBands
CDMA: BC0,BC1
GSM: B2,3,5,8
Thanks!
@BarbaraWong Nothing to worry about will work without any issues. If anything it over qualifies with those specs ![]()
06-10-2019 11:00 PM
Nice phone!! yes it looks like a very capable phone if it doesn't work I will trade you for my iphone 8![]()
06-10-2019 10:55 PM - edited 06-10-2019 10:56 PM
Easiest way to try is to go to a Public Mobile retailer and see if they have a spare card to test. Check your phone is designed for phones that are generally available at retail for North America. It should work but YMMV.
