09-14-2019 03:18 PM - edited 01-05-2022 07:05 AM
"Refer a friend and take $1 off your payment every 30 days for every friend you refer for as long as they stay with us. Your friend will also receive a one-time $10 credit!"
Is this valid for online purchase or can i buy sim from walmart and get the same credit ?
Joining Public
09-14-2019 09:09 PM
The referral code credit applies as long as it's entered on the first activation page (about halfway down the page) . There are a couple of promos floating around that are still available for new activations. Ending today.... purchase a SIM card (I don't think they price match but can't hurt to ask. ) and activate in store at the mobile shop (in most superstores and elsewhere) using your pc MasterCard earn 25000 optimum points ($25 redeemable value) when you spend $50+ before taxes. That would cover a SIM card and $40 plan to receive the points bonus along with any regular points. Wal-Mart currently has a free SIM card with in store activation. London drugs will match that offer. Buy your SIM card and activate online til Sept 30th enter RBCREWARDS in the promo code box on the "plans and add ons" page during activation and receive $10 off any $40+ plan for 6 months when you use a credit card. These are on top of the $10 referral code credit. Be sure to set up auto pay (even if you never use it) to get the $2 monthly reward credit and bonus data (250 mb-500mb) on your plan. If you are porting a number from koodo prepaid or pc mobile or home or internet phone these take extra time or moderator help...up to a week so choose a temporary number to get service and port the number you wish to keep later once you are all set up. Good luck....and welcome to Public Mobile.
09-14-2019 08:34 PM
you also have to be careful, if you do try to vadlidate your plan and there is an issue such as, missing info or wrong credit card info and forces you to go and do corrections, you have to re enter the refferal code.
09-14-2019 03:22 PM - edited 09-14-2019 03:51 PM
@Noreenmukhtar hi you can do it online or walmart just give them your referal code to input on the form
09-14-2019 03:20 PM - edited 09-14-2019 03:29 PM
As long as the code is provided at signup, no matter if it was in. store or online. You should receive sms as soon as your friend signs up, if something goes wrong and you don't get credit you can contact moderators about it. Your friend will get 10 inn couple of days
