One plus 2 Compatibility
tina_lachapelle
Hello Public Mobile Community,
I broke my Samsung and for the time being I am using an older cell that once belonged to my son. It is a One plus 2 . I can make calls, receive and receive texts HOWEVER I cannot send texts in return. Does anyone know how I may fix this??
Please and Thank You🙏
1 REPLY 1
@tina_lachapelle try to click Reset All Networks and it should resolve the issue
But be aware that it will also clear all your saved WiFi and need to readd them after
