08-18-2022 02:45 PM
Hi I have an account with an email that is no longer in use. I’m now locked out of my account and want to update the email. What do I do
My Account
08-18-2022 02:55 PM
Hi @emmaY You can ask PM CS agent to change the email address used for My account login:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
08-18-2022 02:49 PM
you need to contact customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type request email change
2. alternatively you can private message them here
