07-26-2020 11:29 AM - edited 01-05-2022 12:16 PM
I have an old cell phone that I am wanting to activate with public mobile, my question is am I able to activate this cell even though there’s no cell number or do I need to have a number from another provider?
Forgot to mention the cell is an iPhone6, unlocked and was already used with public mobile, the old owner bought a new one and is giving this one to his grandmother
Joining Public
07-26-2020 12:49 PM
If the iPhone6 was very recently used on pm then it probably wont even need updates but her grandson should make sure he removes his info and apple id and help set up the phone with a new apple id for his grandmother so there are no issues accessing itunes, the apple store and data.
07-26-2020 12:28 PM
@lee682 Hi. No, no need for a number from another provider. Just buy a new PM sim and activate it using that old phone. Then create a new PM self-service account using a new email address. You are good to go.
07-26-2020 12:28 PM
@Luddite wrote:Just for your more complete understanding; it is not the phone that is activated but the SIM. The activated SIM can be used in any unlocked, or locked Telus/Koodo, phone.
The activated SIM can be used in any unlocked, compatible phone. Or locked Telus/Koodo phone.
(fixed it for ya 🙂 )
07-26-2020 12:04 PM - edited 07-26-2020 12:07 PM
@lee682 wrote:I have an old cell phone that I am wanting to activate with public mobile, my question is am I able to activate this cell even though there’s no cell number or do I need to have a number from another provider?
Emphasis added. The short answer is no; you do not need a number from a different provider.
Just activate a new PM SIM and put it into the phone. Get a referral code from someone for a credit of $10 on the new account.
07-26-2020 11:59 AM - edited 07-26-2020 12:05 PM
You would need to purchase a PM sim and setup a new account. You can buy a new at Canadiancellsupplies.com.
07-26-2020 11:52 AM
@lee682 hi if it is an iphone 6 andwas used here before then you should be good to go!!😁
07-26-2020 11:52 AM
hi @lee682 , Well it sounds like you are good to obtain a PM SIM card and get the new phone number upon activation. 🙂
07-26-2020 11:42 AM - edited 07-26-2020 11:43 AM
Public mobile uses these frequencies @lee682 if your phone isn't on the lis. The 3g ones are required for talk. They must be there for your phone to work.
Public Mobile 3G & 4G Frequencies.
3G Frequencies 850 MHz, Band 5 (UMTS/ HSPA).1900MHz, Band 2 (UMTS/ HSPA).
4G Frequencies 1700/ 2100 MHz AWS, Band 4 (LTE/ LTE Advanced).
700 MHz A/B/C/E, Band 12/13/17/29 (LTE/ LTE Advanced).
Here is an article on on the refer a friend reward. https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward . By having someone refer you, you get a $10 credit. Welcome to PM. Stay safe.
If you require a sim card an option is to buy your SIM card from Canadian cell supplies https://canadiancellsupplies.com/collections/latest-products/products/public-sim-card . Currently they are $2.99 each.
07-26-2020 11:41 AM
How old is your cellphone? What is the make and name of your old phone?
If it is a CDMA phone without SIM card, it cannot be used with any providers in Canada. All Canadian providers are using SIM card phone with IMEI number.
If you have an old cellphone supports only GSM/2G only from Rogers/Fido/Chatr, you cannot use with PM as PM use 3G for voice call.
You can get a new phone number from PM during activation. You don't need to port your old number to PM if you don't want to.
07-26-2020 11:32 AM
Hi @lee682 ,
Check you phone compatibility here:
https://www.publicmobile.ca/en/ns/get-help/articles/check-your-phones-compatibility
And you can get a new number on activation:
1.What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
07-26-2020 11:31 AM - edited 07-26-2020 11:33 AM
You need to make sure the phone is compatible with PM networks and also make sure the phone is unlocked and not reported as stolen.
What phone is it anyway ?
07-26-2020 11:31 AM - edited 07-26-2020 11:31 AM
@lee682 hello you can pick a new number at activation just make sure your phone is unlocked
